Благодарил (а): 126 раз.
После установки RNS510 и блютуз модуля появилась кучка постоянных ошибок:
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0230
Coding: 002200
Shop #: WSC 01530 935 00200
VCID: F0E547B023153D9EE43-80A5
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 31524 km
Time Indication: 0
Date: 2040.14.09
Time: 11:28:20
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 R HW: 3C8 035 680
Component: RNS-MID H26 6270
Revision: AB001001 Serial number: 0017
Coding: 00000400000000A22000
Shop #: WSC 00000 000 00000
VCID: 3D7B2E84A4C700F6BF5-8068
Subsystem 1 - Part No: 1T0 919 859 C
Component: EU East V12 8196
2 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 82
Mileage: 31520 km
Time Indication: 0
01523 - Microphone for Telephone (R38)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 82
Mileage: 31524 km
Time Indication: 0
Date: 2040.14.09
Time: 11:30:09
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 82
Mileage: 31520 km
Time Indication: 0
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 82
Mileage: 31524 km
Time Indication: 0
Date: 2040.14.09
Time: 11:30:09
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007666838142
Coding: 0A01000000010101
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3C7D2380B7DD09FE88B-8069
2 Faults Found:
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 82
Mileage: 31524 km
Date: 2040.14.09
Time: 11:06:54
13636352 - Control module not coded
U1013 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 82
Mileage: 31524 km
Date: 2040.14.09
Time: 11:06:54
И если с "Control module not coded " все более или менее понятно (как я понял надо прописать любые значения в Work Shop Code, Importer, and Equipment Number) то с остальным не очень понятно, что делать.
И еще вопрос, почему тут какая-то левая дата?
Были похожие ошибки после замены RCD-310 на RNS-510...В Gateway Installation List поставил галку на протиа 37-Navigation, почистил ошибки...Больше подобных ошибок не появлялось...А дата неправильная потому что она в приборке нашего polo и не выставляется, толбко время...
спасибо, действительно включил 37-й блок. почистил и все прошло)
проблема решена тему закрываю.
ОлегV
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 36
