Autodesk Revit 2025.4.2 with Updated Extensions Win x64 Mult
Free Download Autodesk Revit 2025.4.2 with Updated Extensions | 17.5 Gb
Languages Supported *: English US, English UK, Deutsch, Français, Español, Brazilian Português,
Italiano, Русский, Polski, Čeština, Simplified 中文, Traditional 中文, 日本語, 한국어
Autodeskhas releasedREVIT 2025.4.2. Apart from fixes in the detected issues, this update also hosts noteworthy enhancements. All updates are cumulative and include all changes from previously released Revit 2025 updates.
Owner:Autodesk
Product Name:REVIT
Version:2025.4.2 with Updated Extensions *
Supported Architectures:x64
Website Home Page :www.autodesk.com
Languages Supported:multilanguage *
System Requirements:Windows **
Software Prerequisites:pre-installed Autodesk REVIT 2025.0 and above
*NOTE: For each of the supported languages, the Revit software contains translations for the user interface. Revit does not use language packs. Instead, the base language for the software is determined as follows:
-When installing Revit on a single computer:The language (and locale) for the software is based on the computer's regional settings specified for the operating system.
-When creating a Custom Install:The language (and locale) for the deployment image is based on the regional settings specified for the operating system of the computer used to create the deployment.
Languages for Revit content
In a default Revit installation essential language content packs for the 14 supported languages in Revit will be installed. Essential language content is option within Custom Install workflows.
2025.4.2 Update - Release Date: May 29, 2025
The Revit 2025 updates are cumulative and include all changes from previously released Revit 2025 updates.
After this update is applied successfully, the build number specified on the Help > About dialog will be:
- 25.4.20.11
- 20250515_1515(x64)
- 2025.4.2
Software embedded in the update executable:
Core Package - Component for Revit 2025 - version 25.4.20.11
Core Package - ATF for Revit 2025 - version 25.4.20.11
Core Package - Cloud for Revit 2025 - version 25.4.20.11
Core Package - CefSharp for Revit 2025 - version 25.4.20.11
Core Package - RVT Component for Revit 2025 - version 25.4.20.11
Core Content for Revit 2025 - version 25.4.20.11
Dynamo Core for Revit 2025 - version 25.4.20.11
Dynamo Docs - version 25.4.20.11
Dynamo Samples - version 25.4.20.11
Cloud Models for Revit 2025 - version 25.4.20.11
TwinMotion Package Component for Revit 2025 - version 25.4.20.11
Unit Schemas for Revit 2025 - version 25.4.20.11
Generative Design For Revit - version 25.5.6.0
Carbon Insights for Revit 2025 - version 25.4.20.11
Product Feedback for Revit 2025 - version 25.4.20.11
Personal Accelerator for Revit 2025 - version 24.4.21.0
Addins Manager for Revit 2025 - version 25.4.20.11
Important Notes
The Revit 2025.4.2 Update does not support uninstall. Once Revit 2025.4.2 Update is applied Revit 2025 cannot be reverted to its pre-update state.
Autodesk Insight Energy Analysis and Autodesk Green Building Studio will no longer allow new models to be submitted for analysis. Customers will continue to have access to the previously submitted models to these services. To perform analysis, customers will be required to submit their models to the next generation Autodesk Insight Carbon Analysis from Revit 2023.1 and higher.
2025.4.2 Update Issues Resolved
General
- Addressed multiple vulnerabilities in Autodesk Revit. More details.
- Addressed potential RFA File Parsing Vulnerability in Autodesk Revit. More details.
3D Shapes
- Fixed an issue where some complex geometry could not be upgraded.
Export DWG/DXF
- Fixed an issue where hatch patterns were not exported for transparent elements with no background pattern or elements behind them did not export to CAD programs.
File Open/Save
- Improved Revit stability when trying to open or load a corrupt Revit model.
Groups
- Improved stability when working with radial arrays that are grouped and associated.
Licensing
- Fixed an issue where Revit would become unresponsive when the device limit screen appeared.
Link RVT Files
- Improved stability when attempting to use the Manage Worksets command on a Revit link that is invalid or cannot be accessed.
Print
- Fixed an issue where solid fills were missing for elements with transparency in print, export PDF, or export DWG with vector processing where a non-transparent element was displayed in the Underlay behind them.
Autodesk Revit, Autodesk's leading Building Information Modeling (BIM) solution, supports multi-discipline teams throughout the project lifecycle. Available individually or as part of the Autodesk architecture, engineering, and construction industry collection, Autodesk Revit features industry-specific tools for architectural design, mechanical, electrical, and plumbing (MEP), structural engineering, and construction.
Autodesk Revit 2025offers new capabilities and enhancements for site design and toposolids, upgrades for modeling and documenting concrete and steel design, in addition to new features for sustainability and carbon analysis, structural analysis, and MEP analysis and fabrication. There are many community ideas realized in Revit 2025, among them sheet collections which benefit efficiency for everyone documenting in Revit, single element and empty arrays for modeling families, and wall joins which improve the experience of placing and manipulating walls, making it more predictable and less prone to error. There's also more connectivity to Autodesk Docs, improvements for openBIM workflows and data exchange, and other project management upgrades and schema improvements.
What's new in Revit 2025
Autodeskhelps people imagine, design and create a better world. Everyone-from design professionals, engineers and architects to digital artists, students and hobbyists-uses Autodesk software to unlock their creativity and solve important challenges.
Revit_2025_English_Win_64bit_dlm_001_002.exe
Revit_2025_English_Win_64bit_dlm_002_002.7z
Revit_2025_4_2.exe
Autodesk Data Exchange Connector for Revit 2025
Content Catalog Revit 2025 Extension v1.3.10.0
Interoperability Tools v10.0.3.13482 for Revit 2025
Issues Addin v7.0.2 for Revit 2025
Publish NWC Addin v1.2 for Revit 2025
Revit Interoperability 2025.4.1 Update (Revit Core Engine 2025)
Revit Addons Bundle 2024-2025
ALPHA BIM Formwork Area 1.0.4
AlphaBIM For Revit 2025.1
BIM & Scan AutoCor 1.0.0.3
BIMSmartLab Roof Generator 1.0.8749
DQ Projects CALDIMO 1.0.0
DQ Projects dwellings 1.2.0
Elbow Rotate for Revit 1.0.0.0
Engipedia.3d.Room.Tags.1.1.24.1102
EngipediaTopoShaper1.2.24.1020
MODELA.Graphic.Memories.2.1.1
Naviate Fabrication 3.4 (x64) for Revit
PROISAC-BIM-VDC 4D BIM 5.0.0
PROISAC-BIM-VDC Lock-It.with.Password.User.6.0.0
PROISAC-BIM-VDC.Briefcase.5.0.0
PROISAC-BIM-VDC.Dynamic.Quantities.6.0.0
PROISAC-BIM-VDC.ID.Stamper.4.0.0
PROISAC-BIM-VDC.IsoMEP.3.0.0
PROISAC-BIM-VDC.KeyNote.Magic.3.0.0
PROISAC-BIM-VDC.Lock-It.with.Password.6.0.0
PROISAC-BIM-VDC.Open.without.Links.LinkLess.4.0.0
PROISAC-BIM-VDC.Remove.Analytical.Model.3.0.0
PROISAC-BIM-VDC.Room.Intersector.1.0.0
PROISAC-BIM-VDC.Styler.7.0.0
PROISAC-BIM-VDC.Universal.Translator.3.0.0
PROISAC-BIM-VDCGridVerticalExtender4.0.0
Site Modeller Pro For Revit 2.1.0
SPATIAL.CONSTRUX.NCeptionExporter.1.0.0
Uploady
0lm9j.Autodesk-Revit-2025-4-2-with-Updated-Extensions-Free-Download.part1.rar
0lm9j.Autodesk-Revit-2025-4-2-with-Updated-Extensions-Free-Download.part2.rar
0lm9j.Autodesk-Revit-2025-4-2-with-Updated-Extensions-Free-Download.part3.rar
0lm9j.Autodesk-Revit-2025-4-2-with-Updated-Extensions-Free-Download.part4.rar
0lm9j.Autodesk-Revit-2025-4-2-with-Updated-Extensions-Free-Download.part5.rar
0lm9j.Autodesk-Revit-2025-4-2-with-Updated-Extensions-Free-Download.part6.rar
Rapidgator
AutodeskRevit202542withUpdatedExtensionsFreeDownload.html
http://peeplink.in/4adfdafdb5ed
Fileaxa
UploadCloud
0lm9j.Autodesk-Revit-2025-4-2-with-Updated-Extensions-Free-Download.part1.rar.html
0lm9j.Autodesk-Revit-2025-4-2-with-Updated-Extensions-Free-Download.part2.rar.html
0lm9j.Autodesk-Revit-2025-4-2-with-Updated-Extensions-Free-Download.part3.rar.html
0lm9j.Autodesk-Revit-2025-4-2-with-Updated-Extensions-Free-Download.part4.rar.html
0lm9j.Autodesk-Revit-2025-4-2-with-Updated-Extensions-Free-Download.part5.rar.html
0lm9j.Autodesk-Revit-2025-4-2-with-Updated-Extensions-Free-Download.part6.rar.html
Fikper
FreeDL
cron
