SysTools NSF Converter 6.2
Free Download SysTools NSF Converter 6.2 | 56.8 Mb
This NSF file conversion utility allows you to convert complete data. You can easily convert emails, contacts, calendars from single or multiple NSF files. The software is well capable to preserve Meta properties, attachments, and formatting intact. There will be no loss of information experienced while converting NSF file. Also supports migration of Names.nsf file.
Convert NSF into Eight Different File Format
The NSF Converter offers eight file conversion options. You can convert NSF into different formats. In these options, you can convert all the items present within NSF file. After conversion of the files, you are free to use the files in different applications like; Outlook, Outlook Express, Windows Mail, Thunderbird, etc.
Batch NSF File Conversion
Through the NSF Converter tool you can convert multiple NSF files; saved in a common folder. There will be no limitation on the number of files that can be converted. Software allows you to directly select folder having NSF files. Also, you can add the Domino Mailbox by providing a valid Domino Server IP Address using the tool.
Convert Selective NSF File Items
The NSF file conversion program allows you to migrate all the items present within the NSF file such as emails, contacts, and calendars. Now if you want, you can only convert selective items instead of exporting them all. Simply check or uncheck the files to convert the item of your choice.
Convert Lotus Notes Tasks
With the help of the NSF Converter tool, one can easily convert tasks and its associated data items like attachments, and other items into different file formats such as PDF, MSG, HTML, CSV, and TXT. There is no limitation to any file in fact you can also add and convert Domino task data too using this tool.
Option Expot Lotus Notes Data to TXT
The NSF Converter tool allows users to export all the items from Lotus Notes such as emails, contacts, and calendars, and tasks into different file formats. In fact, using this tool one can also export multiple task data, just select the file format and the data item that you want to export.
Operating System:Windows 11 (64 bit), Windows 10, 8, 7 (32 bit or 64 bit) & Windows Server 2016, 2012 R2, 2008
Home Page-
Код:
https://www.systoolsgroup.com/
Buy Premium From My Links To Get Resumable Support,Max Speed & Support Me
Rapidgator
7gd7r.SysTools.NSF.Converter.6.2.rar.html
UploadCloud
Fikper
FreeDL
Links are Interchangeable - No Password - Single Extraction
