AVS Audio Editor 11.1.1.181
Free Download AVS Audio Editor 11.1.1.181 | 79 Mb
Edit your audio files with AVS Audio Editor . Cut, split, merge, record, apply various effects. Save output files to all key audio formats.
Features Overview:
- Edit Audio
Cut, join, trim, mix, delete parts, split. Use Timeline for maximum precision and accuracy. Multichannel audio files are supported.
- Enhance Audio
Over 20 built-in effects and filters including delay, flanger, chorus, reverb, and more. Full support of VST effects and DirectX filters.
- Remove Background Noises
Use specially designed filters to remove irritating sounds like "vuvuzelas", roars of football fans, hisses, etc.
- Mix Audio
Blend several audio tracks, apply effects and save the output file in any popular format. Overlay your voice on audio while playing it back.
- Microsoft Windows 7 Support
AVS Audio Editor is compatible with the latest version of Microsoft Windows.
- Export Audio from Video
Choose and edit audio from your video files. Save them on PC or external hardware. See a full list of supported formats here
- Use Batch Editing
Select effects and settings and apply them to several audio files.
- Save Audio in Key Format
Edit and save audio files in MP3, WAV, PCM, WMA, M4A, Flac, OGG, etc.
- Record Audio from Any Input
Edit your audio recordings, apply effects, save them as separate audio files.
- Create Ringtone for iPhone
Edit an audio file and save it to M4R format for iPhone.
- Work Fast & Easy
Make your Favorites panel. Select the most frequently used features and add them to your panel.
All key formats are supported:
Read: MP3, WMA, WAV, M4A, M4R, AAC, AMR, OGG, MP2, FLAC, AIFF, AU, AVI, IVF, DIV, DIVX, MTV, AMV, MPG, MPEG, MOD, MPE, MVV, M2V, WMV, ASF, DVR-MS, DAT, IFO, VOB, VRO, M2TS, M2T, MTS, TOD, TS, TP, DV, MKV, OGM, OGV, OGA, OGX, RM, RMVB, RAM, IVR, MOV, QT, M4V, MP4, 3GP2, 3GPP, 3GP, 3G2, FLV, SWF
Write: MP3, WMA, WAV, M4A, M4R, AAC, AMR, OGG, MP2, FLAC, AIFF, AU, AVI, IVF, DIV, DIVX, MPG, MPEG, MOD, MPE, MVV, MTS, TOD, MOV, QT, M4V, MP4, 3GP2, 3GPP, 3GP, 3G2, FLV
Operating System: Windows 10, 8.1, 8, 7, XP, 2003, Vista
Home Page -http://www.avs4you.com/
Rapidgator
udrl3.AVS.Audio.Editor.11.1.1.181.rar.html
UploadCloud
Fikper
FreeDL
