Perfectly Clear WorkBench 4.8.0.2830 macOS
Free Download Perfectly Clear WorkBench 4.8.0.2830 Multilingual Fast Links | macOS | 198 mb
Clear Workbench is an application that uses Athentech's Perfectly Clear image correction libraries and is made available to demonstrate the capabilities of the Perfectly Clear processing libraries, face detection library and to allow a quick export of the processing settings for use.
Supported Image Formats:
Perfectly Clear requires RGB-formatted images in either 8 or 16-bit color depth. Any image file that Photoshop or Lightroom can open and convert to this format may be used in Perfectly Clear. Monochrome and CMYK images must be converted to RGB before using Perfectly Clear. RAW files must be opened through Adobe Camera RAW and loaded into Photoshop to be accessible to Perfectly Clear.
Compatibility
: macOS 10.10 or later
Rapidgator
suqoc.Perfectly.Clear.WorkBench.4.8.0.2830.dmg.html
Fikper
FreeDL
