Crocus Soundware LIMINAL: Zephyrian Brass KONTAKT
Free Download Crocus Soundware LIMINAL: Zephyrian Brass KONTAKT | 2,67 GB
Crocus Soundware is pleased to present LIMINAL: ZEPHYRIAN BRASS, a library of intimately recorded Trumpet, Trombone and Valve Trombone samples - playable using the full version of Kontakt 6.8+. The library's articulations are aleatoric, long and evolving, with the performer imparting character and movement into each sample. This library focuses on capturing a wide dynamic range of the instruments, highlighting the uniquely varied timbres hidden within those dynamics. Notably, so-called 'whisper tones' were recorded a difficult technique where the performer uses highly-controlled breaths to produce tone that barely activates the instruments resonance. The result is a fragile sound that teeters between breath and pitch. This technique evokes a warm and airy reed-like character from the instrument.
The audio was recorded using large-diaphragm condenser microphones, placed within centimeters of the instrument's bells. This allowed us to capture hyper-intimate details into the samples. The library is well suited to add unpredictability and creative imperfection. The LIMINAL range is not specifically intended for fast passages or soaring melodies. Instead, you may see the libraries as collections of naturalistic pads - offering humanistic details not found in something derived from a synthetic source.
The user-interface allows articulations to be layered, mixed and reversed. The 'crossfade gizmo' allows artful blending of sound layers with intuitive color-coded controls. LFO controls can also be enabled, allowing your DAW's tempo to dictate the modulation of an individual layer's volume. This opens the door for tempo-synced swells and unleashes even more creative possibilities for evolving texture.
Crocus Soundware LIMINAL: Zephyrian Brass KONTAKT screenshotFEATURES:
- Made for the full version of Kontakt 6.7 or higher (Not intended for Kontakt Player)
- VST3, VST2, AU and AAX compatible host
- 3.34 GB samples Uncompressed (2.24 GB Compressed)
- Includes sample sets of both ensemble and solo performances.
- 12 Core Articulations
- Dozens of Snapshot Presets
LIST OF ARTICULATIONS:
- Whisper Tone Sustains
- Whisper Tone Shorts
- Crescendos from Whisper Tone to Loud Dynamic
- Vibrato Sustains Mid Dynamics
- Crescendos from Moderate to Loud Dynamic
- Forte Piano
- Clustered Crescendo Staccatos
- Clustered Crescendo Shorts
- Trills with Swelling Dynamics
- Muted Sustains
- Muted Crescendos
- Short Bursting Swells
Requires the FULL version of NI Kontakt v6.8.0 or higher!
Код:
https://avxhm.se/blogs/crymeariver
Uploady
jyg4n.Crocus.Soundware.LIMINAL.Zephyrian.Brass.KONTAKT.part1.rar
jyg4n.Crocus.Soundware.LIMINAL.Zephyrian.Brass.KONTAKT.part2.rar
jyg4n.Crocus.Soundware.LIMINAL.Zephyrian.Brass.KONTAKT.part3.rar
Rapidgator-->Click Link PeepLink Below Here Contains Rapidgator
CrocusSoundwareLIMINALZephyrianBrassKONTAKT.html
http://peeplink.in/24513b492f31
UploadCloud
jyg4n.Crocus.Soundware.LIMINAL.Zephyrian.Brass.KONTAKT.part1.rar.html
jyg4n.Crocus.Soundware.LIMINAL.Zephyrian.Brass.KONTAKT.part2.rar.html
jyg4n.Crocus.Soundware.LIMINAL.Zephyrian.Brass.KONTAKT.part3.rar.html
Fikper
FreeDL
