In the ever-evolving world of Path of Exile 2 (PoE 2), the Huntress class stands out with her agility and prowess in elemental projectile attacks. One of POE2 Currency her signature passive skills is Infuse Weapon, an ability that greatly enhances her damage output through elemental infusions applied to her weapons. This skill is tied exclusively to the Amazon Ascension, and mastering it can elevate a Huntress player’s effectiveness in combat significantly. This article delves into how to obtain Infuse Weapon, its underlying mechanics, and tips for triggering and optimizing its power.
How to Obtain Infuse Weapon To gain access to Infuse Weapon, players must first complete either the Trial of Sekhmas or the Trial of Chaos, which are Huntress-specific ascension trials. Successfully finishing one of these trials allows the player to choose the Amazon Ascension path—a powerful class-specific ascension unique to the Huntress.
Within the Amazon Ascension tree, the Elemental Infusion node is the gateway to acquiring Infuse Weapon. This node requires just 2 Ascension Points, meaning that even players who complete the trial on the lowest difficulty can unlock this skill early in their ascension journey. This accessibility makes Infuse Weapon one of the foundational passive skills for the Huntress class.
The Passive Nature of Infuse Weapon Infuse Weapon is a passive skill, which means that it does not require any active player input such as right-clicking or pressing a skill button. Instead, it runs in the background, automatically activating whenever its triggering conditions are met. This allows the Huntress to focus on strategic gameplay without worrying about managing additional active skills.
Additionally, Infuse Weapon is unique because it does not come with a skill gem. This means that it is strictly exclusive to the Huntress class and cannot be used by other classes, reinforcing its thematic and gameplay uniqueness within the Amazon Ascension.
The Weapon Infusion Mechanism Explained To fully appreciate Infuse Weapon’s function, it helps to first understand its parent node, Elemental Infusion. This node details how the Huntress’s weapon gains elemental infusions based on the type of charges consumed. Here’s how the charges relate to elemental infusions:
Using an Energy Charge grants 2 Cold Infusions.
Using an Endurance Charge grants 2 Fire Infusions.
Using a Fury Charge grants 2 Lightning Infusions.
These infusions “imbue” the weapon with elemental power. When the Huntress makes a non-melee projectile attack with an infused weapon, the attack consumes one infusion and causes the projectile to explode upon impact, dealing additional elemental damage in an area.
Important Details About Charge Consumption and Infusions It is critical to note that Infuse Weapon itself does not consume charges. Instead, the player must use other skills that expend these charges, which then triggers the infusion effect on the weapon.
For example, the skill Lightning Lance consumes Fury Charges to trigger the weapon infusion, which then imbues the weapon with a Lightning Infusion. Subsequently, firing a non-melee projectile skill such as Twister consumes the infusion and causes the explosive elemental effect.
Infusions last for 15 seconds before expiring, and the Huntress can hold up to 6 infusions of the same elemental type simultaneously. This means players can maintain a maximum of 6 Fire, 6 Cold, and 6 Lightning infusions on their weapon at any given time through Elemental Infusion.
Steps to Trigger Infuse Weapon Activating the Infuse Weapon effect involves a sequence of actions:
Generate Charges: Skills like Cull the Weak or passive nodes generate Energy, Endurance, or Fury Charges.
Consume Charges: Use a skill such as Lightning Lance that consumes these charges to trigger weapon infusion.
Fire a Non-Melee Projectile: Use a skill like Twister to consume an infusion and cause an explosion on impact.
Huntress Skills That Work with Infuse Weapon Several Huntress skills are designed to synergize perfectly with Infuse Weapon by consuming Frenzy Charges and launching non-melee projectiles:
Lightning Lance
Explosive Lance
Storm Lance
Glacier Lance
Twister Lance
Each of these skills can trigger and consume elemental infusions, making them vital tools in the Huntress’s arsenal.
Efficient Charge Generation Strategies To maximize Infuse Weapon’s benefits, players need a reliable source of charges. The Battle Fury passive node grants Frenzy Charges every time the Huntress uses Electrocute, Freeze, or Cripple effects on enemies. Among these, Electrocute is highly recommended for builds focused on Lightning Infusions because it scales well with increased Lightning damage.
Equipping Kitoko’s unique gloves further enhances Electrocute’s effectiveness, enabling faster charge generation and more frequent weapon infusions.
For players building around cold damage, adding the Resonance Node in combination with Battle Fury converts Fury Charges into Energy Orbs, which then generate Cold Infusions. This synergy is the foundation of the Frozen Huntress build, focusing entirely on cold elemental effects.
The Infuse Weapon passive skill is a cornerstone of the Huntress’s elemental projectile capabilities in Path of Exile 2. Its unique mechanics, tying elemental infusions to different charge types, provide flexibility and power, allowing players to tailor their builds around fire, cold, or lightning damage.
By mastering the generation and consumption of charges through complementary skills and passives, Huntress players can unleash explosive elemental damage, making Infuse Weapon an indispensable part of buy POE 2 Currency their combat strategy. Unlocking and effectively utilizing this skill not only enhances gameplay depth but also solidifies the Huntress as a formidable force in PoE 2 challenging world. Reliable & fast — Trusted by thousands, MMOexp.com delivers safe PoE2 Currency with lightning-fast delivery.
