Adobe Photoshop 2025 v26.9.0.15 Full Portable (MULTi/RUS)
Free Download Adobe Photoshop 2025 v26.9.0.15 Full Portable (MULTi/RUS)
Adobe Photoshop 2025 - The world's best design and image editing app, Photoshop will make any of your ideas come true. Create and enhance photos, illustrations, and 3D graphics. Design websites and mobile apps. Edit videos, create living paintings, and more. Now you have everything you need to bring any idea to life.
Create anything you want.
Photoshop rules the world of design. Posters and packaging, simple banners and professional websites, memorable logos and bright icons - all this is created in the Photoshop application. Thanks to intuitive tools and convenient templates, even a novice user can create something fantastic.
These are not just photographs. These are fascinating stories.
If you are looking for an app for everyday editing or a complete photo transformation, choose Photoshop. It is a complete set of professional photo editing tools that will turn your photos into works of art. Adjust, crop, retouch photos, remove objects and restore old photos. Experiment with color, effects and many other features to make ordinary photos unforgettable.
More creativity. Less routine.
Draw original illustrations, turn images into paintings, or create your own digital masterpieces. Create 3D graphics for animation and printing. Enhance your work with unique patterns and eye-catching effects. Paint with new brushes that work even faster and make lines and curves even smoother.
Some of the best features include:
• Create anything you want.
• These are not just photographs. These are fascinating stories.
• More creativity. Less routine.
Improved Adobe Photoshop Features:
• Improved brush management. Rearrange and store your brushes in a convenient order. Drag and drop to change the order of items, create folders (including nested folders), change the scale of the brush stroke preview, switch between viewing modes, and save pre-created brush sets with specified opacity, intensity, blending, and color properties.
• Improved performance when working with brushes. Don't waste time due to delays when working with brushes. Now you'll notice a significant improvement in performance, especially when working with large documents and large brushes.
• Access Lightroom photos: Upload photos from Lightroom Cloud services directly into Photoshop using Search or the Start screen. Tighter integration across all Creative Cloud desktop and mobile photography apps means all your photos are in sync and accessible from any device.
• Smooth brush strokes. The new smoothing algorithm gives images a more professional look. Change the smoothing level to get sharper lines, even when working with a mouse. This feature is available in the Tool Options panel next to the Intensity and Opacity settings.
• Variable fonts: New font technologies from Adobe, Apple, Google, and Microsoft let you create variations of each supported font with different weights, heights, slants, and other properties.
• Quick Access Menu: Send consolidated copies of your work or links to them via email, text messages, social networks, etc. This feature uses the OS's sending mechanisms, including already authenticated services.
• Curvature Pen Tool: Create paths faster, more intuitively, and more accurately. Move segments directly without changing Bézier handles, just like with the Curvature tool in Illustrator. Double-click to switch between point types.
• Improved outlines. Improved outline design. Choose the color and thickness of lines to make them more visible.
Copy and paste layers. Copy and paste layers in groups, preserving their order and position. No more dragging and dropping layers. Copy layers to the clipboard and paste them wherever you want in a panel, in documents, or between Photoshop documents.
• Improved Tooltips: Learn more about Photoshop tools without leaving the app. Improved Tooltips that appear when you hover over a tool provide descriptions of the tools.
Work with 360-degree panoramas. Edit and export 360-degree panoramas. Photoshop preserves important metadata for working with third-party viewers. You can move around the image, zoom in and out in a spherical workspace for a realistic preview.
• Properties panel improvements: Get more detailed information about assets in Adobe Stock, including title and license status. Browse images and find similar ones on the Adobe Stock site. Edit font properties for multiple selected layers at once, change leading, and more.
• Microsoft Dial support: Built-in Microsoft Dial support lets you quickly access important controls without using a mouse. Control brush settings including size, hardness, opacity, intensity, and smoothing.
• Paste text without formatting. Now you can paste text without applying styles. No more wasting time reformatting text after pasting.
• HEIF support: Photoshop now supports the High Efficiency Image File (HEIF) format introduced by Apple in macOS 10.13 and iOS 11.0. Using the depth data provided by iPhone 7 Plus and later, you can create depth of field effects using the Lens Blur filter.
• Improved Select and Mask: An improved algorithm and faster performance produce more accurate and realistic results, especially when the background color is close to the image color. Other UI and usability improvements include faster Quick Mask and easier viewing mode customization.
• Overall performance improvements: Improvements to the core architecture make Photoshop faster and more responsive, so you can complete your everyday work in less time. Get started even faster with faster load times.
• And much more. Plus: improved performance and stability, faster saving of large files, improved face detection for Face-Aware Liquify, improved Content-Aware Crop and Content-Aware Fill.
Minimum Requirements:
- Processor: Intel Core 2 or AMD Athlon 64 processor; 2 GHz or faster processor
- Operating system: Microsoft Windows 10 (64 bit) versions 20H2 (Creators Update) and later
- RAM 2 GB or more of RAM (8 GB recommended)
- Hard disk space: 3.1 GB or more of available hard-disk space for 64-bit installation; additional free space required during installation (cannot install on a volume that uses a case-sensitive file system)
- Monitor resolution: 1024?768 display (1280?800 recommended) with 16-bit color and 512 MB or more of dedicated VRAM; 2 GB is recommended**
- Graphics processor acceleration requirements OpenGL 2.0-capable system
Assembly information
Does not require installation of libraries in the system. Does not leave traces in the system and registry.
Launch in the system language. Available languages:
Czech, Danish, German, English:International (en_GB), English:en_US,Spanish,
Spanish:Latin American, Finnish, French:Canadian, French, Hungarian, Indonesian,
Italian, Japanese, Korean, Norwegian, Dutch, Polish, Brazilian Portuguese, Russian,
Swedish, Turkish, Ukrainian, Vietnamese, Simplified Chinese, Traditional Chinese,
en_IL, en_AE, fr_MA.
Change language: Edit\Settings\Interface\Interface language: OK.
CameraRaw: located in Photoshop\App\ProgramData\Adobe\CameraRaw,
Edit or delete if necessary.
Neural filters are located in:
Photoshop\App\Roaming\Adobe\UXP\PluginsStorage\PHSP\25\Internal\com.adobe.nfp.gallery\PluginData
Neuro filters work provided that you have an account, if you are not logged in
account, you don't have one, then create one. Menu: Help-Login. When registering, you can
enter any data, and any email, because confirmation is not required. After logging in
You MUST restart Photoshop in your account, otherwise the filters will not work.
If necessary, edit or delete Neuro-filters, after deletion it will be
a new folder with your data has been created.
Since the program is running with administrator rights, drag and drop does not work,
use "Open with..." or "File"\"Open..." or drag and drop image
to PhotoshopPortable.exe or to the PhotoshopPortable.exe shortcut.
In the App folder, you can delete any folders and files if necessary, except:
AppInfo
Program Files\Adobe\Adobe Photoshop 2025
Program Files\Common Files\Adobe\Adobe Photoshop 2025
Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\IPCBox
Program Files (x86)\Common Files\Adobe\caps
Program Files (x86)\Common Files\Adobe\Color
To finish the job, the launcher terminates all Photoshop processes, returns folders and
necessary keys, cleans the system and registry so as not to disrupt these actions when
When the work is completed, you MUST wait for the message:
"Photoshop END OF WORK".
Whats New in Adobe Photoshop
Код:
https://helpx.adobe.com/photoshop/using/whats-new.html
Information about the program:
Year of issue: 2025
Platform: Windows® 11/10 (64-bit only)
Interface language: Multilanguage / Russian / English
Medicine: not required / built-in | pre-activated
File size: 6.59 GB
Rapidgator
Adobe_Photoshop_2025_26.9.0.15_Full_Portable.part01.rar.html
Adobe_Photoshop_2025_26.9.0.15_Full_Portable.part02.rar.html
Adobe_Photoshop_2025_26.9.0.15_Full_Portable.part03.rar.html
Adobe_Photoshop_2025_26.9.0.15_Full_Portable.part04.rar.html
Adobe_Photoshop_2025_26.9.0.15_Full_Portable.part05.rar.html
Adobe_Photoshop_2025_26.9.0.15_Full_Portable.part06.rar.html
Adobe_Photoshop_2025_26.9.0.15_Full_Portable.part07.rar.html
Adobe_Photoshop_2025_26.9.0.15_Full_Portable.part08.rar.html
Adobe_Photoshop_2025_26.9.0.15_Full_Portable.part09.rar.html
Adobe_Photoshop_2025_26.9.0.15_Full_Portable.part10.rar.html
Adobe_Photoshop_2025_26.9.0.15_Full_Portable.part11.rar.html
Adobe_Photoshop_2025_26.9.0.15_Full_Portable.part12.rar.html
Adobe_Photoshop_2025_26.9.0.15_Full_Portable.part13.rar.html
UploadCloud
Fikper
